- Oct 13, 2017
- Location
- Llandrindod Wells, Powys
- Model of Z
- Z4 SDrive 23i M Sport 2.5Ltr. H.T Convertable
Well, my Z4 goes into the shop for a body make-over a week today. While it's there the owner, Russ, has kindly said he will put it on the ramp so I can work on other bits. Oh joy! working in the warm
I'm going to replace the copper brake pipes and thought that while I am at it I can replace the hoses too. Whilst looking for prices on the web I came across two different sizes of hose for the rear. Both for the 2003, Z4 E85, 2.5i. One, which I presume is the 'standard' one, is 235mm and the other is 680mm. Is the longer one for re-routing for a 'mod' of some sort?
I also need to sort the nearside (l/h) headlight out. There is a lot of condensation in there and I am thinking that the seal has gone, also, I think one of the fixing lugs has broken, as when the bonnet is lifted the headlight is loose. If cleaning, drying out and re-sealing work okay, then I'm sure I can sort out the lug problem. But, in case it is not possible then I will be needing a new headlight. Any idea's where to go for one, please? The only one I have seen S/H was up in Scotland, and was advised to collect rather than have it sent by post. A long way to go, especially at the moment!!
Last query, I would like to fit 'Night breaker' bulbs as I have read on the forum that quite a few of you have used them with success. But which ones do I need/get? There seem to be so many choices.
Cheers all, Colin.
.I'm going to replace the copper brake pipes and thought that while I am at it I can replace the hoses too. Whilst looking for prices on the web I came across two different sizes of hose for the rear. Both for the 2003, Z4 E85, 2.5i. One, which I presume is the 'standard' one, is 235mm and the other is 680mm. Is the longer one for re-routing for a 'mod' of some sort?
Cheers all, Colin.
