i know this has been covered but i cant seem to get this one fixed.
basics....m43 integrated key fob x 1 of
drivers side actuator not working you have to open it manually after turning off the alarm.
went to car to open it pressed key fob and nothing but you can here it trying to fire the actuator.
changed battery in fob still not opening.
checked fuses and are fine.
opened drivers door with key and the alarm sounds.
checked boot loom (already been done last year) with multi meter and its fine.
tried boot lock opens and shuts but wont fire passenger door lock.
when i open the drivers door manually and try to open the passenger door from the inside its remains locked (door pin goes up and down but its dead locked)
kind just run into a dead end with it now as you cant enter the car without the alarm going off.
anyone got anymore ideas?
