Just got a real surprise....
Finished working on my hood (had to respray the front bar fixing the hood to the top of the windscreen) and then decided to move the car into a better parking position on my drive.
My foot went straight to the floor with no resistance from the clutch pedal.
The combined brake / clutch reservoir is up to the normal level.
There is no evidence of fluid leakage from either the master or slave unit.
Reading what I can find, it looks like the clutch master cylinder has failed probably due to the internal piston rubber seal giving up the ghost.
Before I rush out and replace this, can any body confirm or advise otherwise???
nb prior to this the clutch has been working fine. No problems seen at all.
