Code p1622 - Temp Gauage always in the middle
donutholer
Like the title says, I scanned the car and am getting code p1622. Seen online that replacing the thermostat is a good fix for this. however I heard something else can also break the thermostat? I don’t want to replace it and have it break again.
any advice with this code before I buy parts?
Google AI info
AI Overview
BMW code P1622 typically indicates a MAP (Manifold Absolute Pressure) cooling thermostat control circuit electrical fault. This code suggests a problem with the thermostat housing sensor or its associated wiring, potentially affecting engine cooling.
Here's a more detailed breakdown:
Possible Causes:
