Charlotte of Kent
- Mar 11, 2015
Hope I am asking this question in the right place .....
Having suffered two dead batteries in 3 years in my 2006 Z4M roadster (probably because I don't drive it enough, mechanic has checked the electrics and has pronounced them sound) I have now purchased a CTEK battery charger to give it a little help now and then, but not knowing too much about electrics I am wondering - where do I connect the black minus clamp?
The red plus clamp obviously connects to the the positive battery terminal, but the CTEK manual suggest (for batteries mounted inside a vehicle, which mine is) to "connect the black clamp to the vehicle chassis remote from the fuel pipe and the battery" unless my battery is positively earthed, in which case I should "connect it to the negative battery pole and connect the red clamp to the chassis as above.
There is also a nice little drawing showing both clamps connected to the respective battery poles.
Confused? Yep, I am, thoroughly ...... can anyone help me before I tie the thing in knots?
Thank you all so much in advance
