One scruffy item on my Z3 are the aluminium kickplates on the door sills. There are quite a few spiders webs of corrosion. Any tips for refurbishment or are they available to replace? I’m guessing they’re glued on.
zroadster.org
Thanks for that. I think I’ll have go at polishing them after seeing the price of a pair on the bay of thieves!This thread might be of some help :-
Door sill plates the aluminium ones with z3 roadster on them
When cleaning around the inner door areas I caught the cloth under the edge of the above and it pulled up the first couple of inches leaving a crease in the aluminium. If I can remove I am sure I can remove the cresse. Thought I had read about removing them but cannot find. Anyone removed one...zroadster.org
@AllanI These are good.
BMW Z3 repair kit stainless steel sill plates for BMW Z3 Roadster engraving
Orginal Tuneon stainless steel door sill trims BMW Z3 Roadster engraving Roadster Complete set for all 2 strips (left and right) More robust than the original - because instead of aluminum strip we supply stable strips of stainless steel. The cheapest alternative to the complete...www.tuneon-design.com
