Door speaker grille removal
Barry Gadd
Woking Surrey
Z3 1.9L
The grille mesh is looking very tatty on the 2 door card speakers.
How do I remove these? Do they just prise out or do I need to remove the door cards?
If I remember correctly they are screwed in from the back side of the door cards, so you will need to removed them.
Been a while since I had the door cards off though! Door card removal isn't the worst job, as long as you take your time and apply pressure in the correct places.
This is the only vid I could find. Hope you read German.....
View: http://youtu.be/B1n-gH1rijI
To remove the door cards you will need:
1 x Small flat bladed screwdriver
1 x large flat bladed screwdriver
1 x Torx driver or medium Phillips screwdriver depending on what's holding your door trim on!
Proceed as follows:
1. Remove the external mirror switch by carefully prising it up with the small flat bladed screwdriver and pulling it out.
2. Disconnect the wiring and remove the screw holding the door card to the door (it could be a Torx or Phillips head depending if anyone's been in there before you!):
3. Remove the trim around the interior door release handle by lifting it at the rear and sliding the trim forwards:
4. Pull the door trim away from the door by removing the push fit fasteners around the sides and bottom of the door (use the large flat bladed screwdriver to lift the trim and then get your fingers in and pull either side of each fastener). Be careful doing this as they are plastic fasteners on a wooden board and break quite easily.
5. Remove the door trim by raising it at the front first and then progressing to the rear. As you pull the trim away from the door remember to disconnect the speaker wiring.
Thanks for the replies.
I feared I might have to remove the door cards........
I'm going to have another attempt to get Nellie through the MOT next week.
One of the fog lights is bust but I can get a replacement on Ebay without spending a fortune.
Are many people going to the show in Bristol in August?? If the car passes the MOT I'd like to attend.
A screwdriver can both scratch the door paint, and pull the fastener bases off the door card, where they are only held by epoxy which can pry off:
http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/Doorpanelfastener_zpsa53600a0.jpg.
I first roughly located the fasteners:
http://www.bimmerfest.com/forums/showpost.php?p=3845005&postcount=58
and then used a flat forked plastic prying tool made for removing trim.
I lifted the door card from the rear to the front, following these:
http://www.waycoolinc.com/z3/bimmerdump/62178.html
http://www.badenscarpages.ca/m-roadster-stereo-upgrade/ (Begin reading at #27)
With the card off, I found one speaker had broken from its little mount in the plastic grill mesh, so I ordered another speaker (comes with mount). I did not need to remove the grill, but I think one end snaps in and the other has a screw.
I used this occasion to remove the plastic membrane, lube the plastic window sliders, replace the rubber gasket under the outside door handle, clean out the bottom of the door and the drains at each end, re-adhere the foam cups protecting the door pulls from water, and replace the plastic sheet membrane with the later rigid foam membrane.
In reinstalling the card, I noticed that the upper end of the door pull was loose. The base of it's screw mount was broken, and the plastic post with its melted flared end was also broken. So I ordered and new door pull and installed it, and repaired the old ones' base with epoxy which won't be as strong as new. The plastic post from pull to panel will have to be replaced by a screw from panel to pull, if and when the old pull is used again.
http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/Z3 Door Pull Handle/32Pullbaserepair2_zpsaf8fb0b8.jpg
When replacing the card, coat the rubber gasket across the top of the door with silicone (clear dielectric grease). The card will slip in easily, and also remove easily the next time.
The mesh grilles are held in by bent tabs, you will need to pry these up to. Remove from the holder. Door cards will need to come off and the tweeter housing unscrews, use a plasticote type paint.
was thinking of spraying the speaker mesh with satin black, anyone any other suggestions?
That tends to be the usual option. Some people highlight the edge of the grill with a matching colour to the interior, or in some case match it completely to the interior. Depends on how much colour you are looking for!
Plasti-kote Super Matt black is perfect for car trim, it matches BMW black plastic perfectly.
http://www.diy.com/nav/decor/paint-...te-Super-Spray-Paint-Matt-Black-400ml-9253990
This was the silver gearstick surround I sprayed black in a 3 series, it matches the black on the iDrive controller perfectly...
I used this on the tweeter grilles in my Z.
It's not plastidip, it is a spray by plasti-kote, but gives a very oem looking finish.
Cool, didn't realise you could get plastidip off the shelf in B&Q.
I didn't realise either doh, lend me your specs Gary :)
