E85 Cat back exhaust
koolflyer
Z3 2.8 Roadster
Has anyone had to buy a 'Cat back' exhaust for an E85 Z4 recently? The flange onto the exhaust manifold has failed due age on one of our 2.5L Zeds. Any leads and prices would be very useful.
KF
Lee
Basingstoke
Z4 Coupe 3.0si
Thanks Lee, we'd seen these but good have a recommendation. Presumably as you've had three of these, you are happy with quality and fit?
Cheers KF ;)
Yeah the quality is very good. My only recommendation would be buy your own exhaust gaskets for the down pipes. The gaskets in the kit are one use only.
Easy to fit as it comes in sections and all the hangers line up perfectly.
koolflyer
Z3 2.8 Roadster
Thanks Lee, I've been in touch and seemed very helpful plus in stock. Also just checked with S/steel exhaust I had put my Z3 and that is T304 grade too. Again thank you for your help :drinks:
koolflyer
Z3 2.8 Roadster
Just one more question Lee, does the kit come with all the fittings (rubber hangers, bolts etc)?....... and I understand buy own gasket...ta.
Lee
Basingstoke
Z4 Coupe 3.0si
Comes with all the bolts but you will need to buy your own rubber hangers. X3 I believe.
