E85 Z4 Front Lower Arm Rear Bush
MAURICE THE MARTIAN
Tameside-via Mars...or..SK16.
Z4 3.0SE AUTO
I changed mine 6mths after getting the zed .
Massive difference as mine tramlined for fun .but now razor sharp .steering.
Some peeps find em too harsh tho.but not me.
Also changed the rtab bushes as it twiched when cornering and switching left to right quickly.no rear end movement now
Mine is a bit "twitchy" on the front mate and probably a bit worse with the 18" wheels if I'm honest. I'll be putting the original 17" wheels and R/F tyres back on when I refurb my 108's so will compare then. Thanks mate.
GazHyde
Administrator
Administrator
Global Moderator
Berkshire
Z4 MR
Lee has fitted them on the front of his Coupe, and has sorted some of the issues he had. He got fed up after having 2 consecutive failures of OE quality ones. Clearly don't make them strong enough.
If they help keep him on the road then they should help anyone else out ;)
Fair comment Gaz, thank you. I looked on eBay.com tonight but all Powerflex bushes for sale are shipped from the UK!
Neilc
Bit cheaper for you, might have to get some myself as well. Anyone know why the all black is more expensive?
Cheers for that Neil, nice one.
Neilc
It gets better. Enter promo code fast10 for another 10% off
:thumbsup:. What make of strut brace is on your car please Neil ?
ps. I have my eyes on one fron California but would need 48" inside length of a suitcase to get it home;)
Neilc
Neilc
The only issue with the front one is the bonnet open switch mounts where the fixing bolts are at the rear fixing so you have to get a little creative to remount it. The rear one fits with no major issues, I bought new mounting nuts for the rear one as the OEM ones have an outer ring that makes the diameter to large so the edge hits the brace and the nut wont go on.
Neilc
Do you know if the bush diameter is the same on the 2.5 si model as they list 2 types one is 60mm and the other 66mm
I don't know Neil, I plan on measuring mine next week so I know what I need to buy.
GazHyde
Administrator
Administrator
Global Moderator
Berkshire
Z4 MR
Because the blacks are for track! I'd go with the standard purples, unless you drive incredibly hard.
Neilc
Yeah I discovered that after reading a little. I think the black were a hardness of 95 and the purples are 80. Just have to wait for my purples to turn up then work out how to fit them. Could be interesting
Neilc
That's the rear one in the boot.
