Can anyone tell me how to remove the Roll Hoop plastic outer covers on my Z4 please?
.Would something like a wallpaper scraper do the job?I removed mine when I fitted the wind deflector. I eased them apart very carefully with a coule of flat blade screwdrivers until I could get my fingers in and only broke one clip. Still went back together ok - you wouldn't have known.
Did you do that to locate the fixing screw holes for the side brackets Dave?I removed mine when I fitted the wind deflector. I eased them apart very carefully with a coule of flat blade screwdrivers until I could get my fingers in and only broke one clip. Still went back together ok - you wouldn't have known.
Not quite Tony, it was to fit the deflector into the hoop itself. The centre fixing brackets I did by eye.Did you do that to locate the fixing screw holes for the side brackets Dave?
Possibly Ian but it may be too long to be able to get enough purchase on the covers. BMW in their wisdom have gone for one time fixings. In fact if you buy the wind deflector from BMW it is very expensive as it comes with new roll hoop covers because they are expected to break.Would something like a wallpaper scraper do the job?
Nice and thin and plenty of edge to prise a decent amount apart rather than pressing on a small area.
Yes it was Tony, I just eyeballed where the brackets had to go. I had to split the plastic cover to fit the deflector inside the hoop.Mine just has a bracket on each roll hoop which the deflector slides down into and clicks in position, yours not like that?
