E89 Adaptive headlights issue
Greg Wootton
Hello, I have an E89 28i on a '62 plate, noticed last night the main beam is way too high, as per the title it has adaptive headlights so there is no manual adjustment on the dash...does this indicate the module has failed ?? thank you, Greg
Redline
Nuneaton
E89 20i msport
Main beam? There is no setting or that.
Main beam is obtained by a shutter that is moved in the headlight which opens the whole aperture. Dipped uses that shutter to create the beam pattern.
There will a levelling device linked to the suspension front and/or rear. It's possible that it is broken or failed. Seeing a few days having this issue lately.
