Electronic Damping Control Malfunction - Assistance
Admills69
I have a 2016 Z4 sDrive 35i the EDC error just popped up a few days ago.
My challenge is I can't find it, I've looked in the trunk on the right side behind the molding and there is nothing there.
I then looked under the hood by the firewall and the black box only has the ECU, no EDC module behind it.
So I'm trying to determine my next steps, not many diagrams online. I going to remove each wheel and see it there is a wire loose or broken on the shocks.
When I scan the car the EDC does not come up in the scan, so that's been interesting.
I'm open to any suggestions.
B21
Scottish Borders
E89 35is
So the edc computer sits in the sealed black box in the engine bay..
Do you have adaptive dampers?
What does your vin decoder say?
Admills69
I have checked the seal black box in the engine bay close to the fire wall. After removing the 11 torx screws, the only thing in the box is the ECU, its my understanding that the EDC is a small box that sits in the next bay. Mine is empty.
My VIN decoder does not show EDC , it shows I have Electronic Stability Control (ESC) & Traction control.
B21
Scottish Borders
E89 35is
Therefore you don't have electronically controlled dampers..very few 35i did have..simple
Admills69
Spend most of yesterday researching this, It appears I have a VDM (Vehicle Dynamics Module), The EDC is a subcomponent within the VDM that manages your shocks.
Check out this BMW documentation page 70
What I'm going to do is take the car back to CarMax, I've only had the car for 29 days and have only driven it 144 miles. Its still under there 90 day / 4000 mile warranty. My extended warranty kicks in after that.
B21
Scottish Borders
E89 35is
I’m struggling to understand what you’re struggling with?
You have a 35i with conventional dampers?
