I've said it before on here and I'll say it again
Cif Bathroom Mousse
Not the ramblings of a nutter. They are the UK version of
@t-tony 's Scrubbing Bubbles (USA). I sought them out after he mentioned the type of cleaner some time ago.
You spray the mousse on. Leave it 2 minutes. Agitate it with a cheap 2" paint brush. And rinse off with a hose running gently.
You only need to cover the alternator up with a 10p re-useable supermarket bag. And spray a bit of WD40 onto all electrical connections after.
We've used it time and time again, including on engine bays and it works better than ANY purpose made degreaser of ANY price I've ever found. It's £2 a can.
You can use it on the under bonnet insulation but I would remove that first. That will allow you to clean the underside of all the bonnet too. I do tend to put a plastic sheet over the engine when I do that. No need to flood the engine if you help it.i
Here's some photos of an engine out job but we've done several engine bays with it in too.
Before
During
After
Good old Cif
