fault code p1593
rudge
Hi all i have been chasing this fault for sometime firstly the code was for inlet camshaft solenoid so i swapped them over but the fault remained on the inlet solenoid . next port of call is the wiring so checked for resistance now bare with me i am new to this so green wire on solenoid 0 on both inlet and exhaust now i think it was a red wire on both 4.2 With regards to the code 1593 it says it maybe disa valve i have removed this and seems to function well.Does anyone have any thoughts on this fault.many thanks
Did you clear the code after your swap?
Yes but just came back again. I think i may have to get a bmw specific tool to see if i can get in more detail of the fault.The car starts and idles ok but give it some gas and it bogs down and you can smell the fuel.
From Google;
AI Overview
Why am I getting a check engine light with no error codes ...
BMW fault code P1593 typically indicates an issue with the VANOS system and can be caused by improper camshaft timing or a sensor failure. This code can also relate to an open ground line. Replacing the VANOS solenoids often resolves this problem.
Possible Causes
  • VANOS System Malfunction: The code often points to a problem with the Variable Nockenwellen Steuerung (VANOS), which controls camshaft timing.
  • Sensor Failure: A failed sensor can also trigger this code.
  • Open Ground Line: An open circuit in the ground line can cause the fault.
Symptoms
  • Improper Camshaft Timing: The most common symptom is incorrect camshaft timing.
  • Fluctuating Tachometer: The engine's tachometer may show inconsistent readings.
Solutions
  • Replace VANOS Solenoids: In many cases, replacing the VANOS solenoids will fix the issue and clear the P1593 code.
  • Inspect Ground Lines: Check the ground lines for any breaks or issues.
  • Diagnose Sensors: Perform diagnostics on the associated sensors to identify and replace faulty ones.
Note: For a proper diagnosis and to confirm the exact cause, it's best to have a BMW technician use a professional diagnostic tool to read the fault code and perform relevant checks.
  • HOW TO REPLACE VANOS SOLENOIDS CODES P1593 ... - YouTube
    Feb 26, 2023 — When VANOS are bad you will get improper camshaft timing codes like P1593 and P1327. Also your tachometer will fluctua...
    YouTube ·
    findfixxflip
    4:58
  • Reading BMW Codes without a scan tool / BMW E90 320d ... - YouTube
    Jun 19, 2020 — once you get to the check icon you're going to press the BC. button which is here to get into. the check. control. onc...
    YouTube ·
    Preshaan Briglall
    56s
  • OBD II Fault Codes p1593
    OBD II Fault Code P1593 : * Sensor failure. * Ground line open.
    micro-tronik.com
  • Show all
Dive deeper in AI Mode
