Fishing about in the dark
RickyBobby
Sheffield, South Yorkshire
35is
An exercise I like to do shortly after acquiring a new car as it often provides an indication of how much the car has been 'messed about with' - it's amazing some of the crap I've found tucked away behind the stereo :oops:
Although having owned this one before I must have been here before, but on the basis I struggle to remember what I had for breakfast it did feel like I was looking at it for the first time.
Anyway I found the original stereo and harnes intact - I do vaguely remember putting that in first time round to replace a modern flip-off unit. But if I did it the original harness must have had an adapter that I could easily remove.
What I don't remember is this - which appears to be a spare switch unit.
And this which seems to have a 2amp fuse attached to it.
So my question is what have I found if this is the exterior set-up?
Thanks muchly in advance :thumbsup:
According to the part number (8366215) on the first one, that's the "radio contact" belonging to the alarm system. There's a pin on the back of your radio which activates it when removed.
Thanks - so should it be attached tot the radio then?
Garrie if you take the radio out and peer in see this bit here
Clips into that .
Part of the stereo anti theft system so as well as the unit having a code the pin on rear of unit engages into that switch and when alarm activated if stereo removal attempted will set off alarm.
Stephen.
The good old days …when car stereo crime was a thing. 😁
