Flush and oil change
I had a spare hour this afternoon as work had slowed a little so asked if I could change my oil and filter. I put the Forte flush in last night and ran it to work this morning.
While the oil was draining, instead of hiding behind a cupboard and toolbox I decided to sweep the floor under this ramp and the one next to it. Look at the floor under the car, bloody disgusting.
I swept up over half a barrow load of crap.
Anyway the motor sounds better for it, it's a very good product. I will probably have a few bottles at ZedFest so if you would like one let me know.
miller1098
Carno,Welsh Wales
M
:thumbsup:Always flush ours and change the oil every 12 months whatever the milage cheap maintenance :thumbsup:and it's something you can do easily;) Sarah's gets a set of plugs as well not quite so often on the m £10 a pop
Faheem
Leicester
1.9 M44
Good work Tony. Out of pure curiosity how many litres does it take being that it's a 3.0l monster?
I've changed my engine oil 3 times in the past 6 months. =)) Not because I'm ocd about maintenance but because of all the issues I've had with the rough idle. The rough idle is almost non existent. It seems to be that when ever the oil gets low, i.e halfway between the min and max on the dipstick the rough idle is more obvious, which happens too quickly. Need to determine the cause of the leak. Suspect its the sump pan gasket.
I might buy a bottle of forte engine flush from you, heard good stuff from other sources, especially about their fuel treatment apparently. How much are they paying you? :D
mwpe
Camberley
I would like a bottle of that please Tony, See you at Zedfest.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
Sounds as if you already knew you were going to get a spare hour to do an oil and filter change by already putting a flush in last night =))
Thank you Mike, I'll put your name on one.:thumbsup:
Not really mate, but I was expecting a down turn soon and the Forte product you can run for some time before draining as it has very good lubricating properties. Today was the day :thumbsup:
g8jka
Telford, Shropshire
Not really mate, but I was expecting a down turn soon and the Forte product you can run for some time before draining as it has very lubricating properties. Today was the day :thumbsup:
It just sounded pre-planned :thumbsup: didn't realise you can run this for a while before a change. I might get some off you at Zedfest.
Their Rep. is usually quite generous with product for our own use to be honest Faheem, but they are very good anyhow. I'll have some Petrol and Diesel fuel treatments as well, like last year.
Their Rep. told me that 3 years ago when I had my Z3 mate, I used it for 2 days before draining it and when I refilled the oil I also added some Wynn's Hydraulic Valve Lifter Concentrate for good measure and the motor ran quiet as a mouse after that.
Bozzy
Long Eaton.
I've been using the Wynne's engine flush but you can only leave it in for about 15 mins with the engine ticking over,must be more aggressive than Forte ?.
It has little or no lubricating properties Steve and as you say a quite aggressive action. When we flush Diesels at work, when they're in for Test and service, we put the flush in the engine before warming the oil to do the smoke test.
Tony
Bozzy
Long Eaton.
Tony
Does that lower the emissions temporarily then Tony ?.
No mate, it just kills two birds with one stone is all. IF you test cars properly, you SHOULD get Diesels up to 80 deg.C before doing a smoke test, and if it needs servicing after the test the oil is already hot enough to drain.
The problem we have at work is 2 ex Halfords clowns who put a car on a ramp and fanny around looking for Add-on work before evening draining the oil. Me, I'm old school, drain the oil while it's hot, and while it's draining do something else (sweep floor!) or lower ramp and remove wheels, check brakes etc. But I'm just old fashioned .................... :(
Bozzy
Long Eaton.
Old school is best in my experience anyway mate. As someone said on here recently "old is gold" :thumbsup:.
I agree Steve, but as I said ................. ;)=)) I'm a little biased mate.
Bozzy
Long Eaton.
Well I feel quite sure that if we held a pole on who we'd rather have working on our cars,the choice being the ex Halfords boys or you,the scales would tip heavily in your favour ;).
Cheers mate, I do appreciate that Steve.:)
By the looks of things it may mean an extra GRILLED sausage bun on Sunday mate. Weather forecast isn't promising.:( And if no BBQ Bananas, maybe Key Lime Pie ??
