heath
Hi everyone, I am thinking of changing the front suspension top mounts on my 2000 2.0 Z3 to help cure the tramlining. I have done everything else & changing tyres made the most difference but its still not right. I have looked at the Z3M tops & M3 tops which alter the camber & castor but the 1995 M3 tops only alter castor so I would rather go for these.
My question is ... Has anyone fitted these tops & if I change them but keep my springs will the springs hit the inside of the suspension turrets as the new top mount will move the spring back from its original position. Also do I just need the top mounts or would I need other parts
