Headlight disassembly.
R2nd2
The wiring insulation inside my driver's side headlight is largely missing. Noticed when I was changing out the turn signal lamp. I have pulled the headlight but can't access much of the wiring to repair so I was wondering if the assembly can be taken apart.
These are not made for taking apart. Like the Z3 headlights which are built using meltable adhesive, the Z4 headlights are not. Perhaps a previous owner has tried (and failed) to disassemble this one?
GazHyde
Administrator
Administrator
Global Moderator
Berkshire
Z4 MR
I've seen some opened and it's honestly a nightmare, mainly carried out with a small cutting disk on a Dremmel and a huge amount of patience.
Bigwinn
Lincoln UK
Z4 3.0i
Hiya
I’ve done a full strip down without cutting apart etc- however it does need the headlights off the car
do you want me to send you the link?
Stuart
Yes please.
Bigwinn
Lincoln UK
Z4 3.0i
Yes please.
Bigwinn
Lincoln UK
Z4 3.0i
Didn’t go into huge detail- however when the lights are off and the backs are off then you can unscrew the 4 bolts holding the projector in- small fingers from that point on as that’s as far as the disassembly goes without cutting
Cheers mate, I'll have a look at that.
Davyhoogy
Sunderland
'98 2.8 z3
Can we not mention meltable headlights please Tony, still a sore subject...
