Welcome to ZRoadster.org - BMW Z1 Z4 Z8 Z3 Forum and Technical Database
If you want to join in with the discussion, and see the areas which are available only to members then sign up now!
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
HELP! Engine Management Light on and no power...
Discussion in 'Z4 Roadster & Coupé' started by ZedLeppelin, Mar 1, 2016.
  1. ZedLeppelin
    ZedLeppelin Dedicated Member
    Supporter British Zeds
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    Hi everyone,
    I have just had an engine management light come on and my car has either gone into limp home mode or has seen a massive loss of power (2.0litre 2006 z4, 67k miles).
    There is now no acceleration whatsoever but the car does start and allows me to drive it. Is it ok to drive still? It will cause me havoc at work if I can't :/
    Any ideas as to what the problem might be? expensive to fix?
    It seems to come out of the blue which is odd. I have seen that it could be an 02 sensor, camshaft sensor or even spark plugs if it is due to a misfiring cylinder? Could this be correct?
    I am praying this is not an expensive fix :(:nailbiting:
    If anyone could offer suggestions or has had this happen themselves then I would be grateful for their input.
    Thanks in advance
    Matt
  2. Antm72
    Antm72 Zorg Expert (II)
    May 4, 2015
    6,783
    4,449
    240
    South Yorkshire
    Model of Z:
    2.8
    It sounds like limp mode any number of reasons and the easiest to answer it would be a code read.Most limp modes restrict the engine to about 30mph so they go but when you hit that it will go no more.
    There may be somone local to you that can read the codes for you and clear them.
    • Like Like x 1
    • Agree Agree x 1
  3. BMBabe
    BMBabe Zorg Guru (V)
    Staff Member Supporter British Zeds Community Admin
    Sep 4, 2014
    9,315
    7,207
    190
    Aylesbury
    Model of Z:
    Z3
    • Like Like x 1
  4. BMBabe
    Sep 4, 2014
    9,315
    7,207
    190
    Aylesbury
    Model of Z:
    Z3
    @ZedLeppelin sorry but I don't have an answer but I have tagged some Z4 owners on your post who may be available to help :thumbsup:
    • Like Like x 1
  5. mwpe
    mwpe Zorg Guru (IV)
    Dec 8, 2011
    3,124
    2,646
    168
    Camberley
    Model of Z:
    3.0
    I have got a basic code reader if you want to try it, I only live in Camberly just off the Maultway.
    • Like Like x 2
  6. t-tony
    t-tony Zorg Expert (II)
    Supporter British Zeds #ZedShed
    36,643
    16,891
    Model of Z:
    Z4 3.0 Auto
    Hi Matt, sounds exactly like mine did when the Inlet cam sensor failed. Absolutely gutless, but just driveable.
    • Like Like x 1
  7. GazHyde
    GazHyde The Gaz Monkey
    Staff Member Administrator Global Moderator British Zeds
    Dec 2, 2011
    15,457
    9,814
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Code reader first, sounds like a Cam sensor but could be as simple as the MAF or a split in the induction hoses.
    The other possibility with the 2.0 Z4 is the exhaust manifolds are known to have issues @EnthuZiaZT Mike knows about that, but not sure if it causes this kind of issue.
    • Like Like x 1
  8. t-tony
    36,643
    16,891
    Model of Z:
    Z4 3.0 Auto
    We had a 2.0 in at work with cracked manifold and while it did trigger the EM light the engine ran ok. Code reading is always the first port of call.
    • Like Like x 1
    • Agree Agree x 1
  9. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    Thank you everyone - I really appreciate your help! Looks like code reading is a first point of call and now at least i have some ideas as to what it could be. You are all awesome - thank you!
    • Like Like x 1
  10. t-tony
    36,643
    16,891
    Model of Z:
    Z4 3.0 Auto
    You can buy yourself a basic code reader cheaply enough off eBay Matt. They're really easy to use too. Shame you're not closer to me.
  11. EnthuZiaZT
    EnthuZiaZT Zorg Guru (V)
    British Zeds East Anglian Crew
    Dec 6, 2011
    4,690
    2,264
    193
    Heacham Norfolk
    Model of Z:
    Z4 28i Msport
    When the engine management light came on, on mine. The engine continued to run perfectly well, no loss of power. The diagnosis was a cracked manifold.
    This sounds like it could be something else, cam sensor, maybe even a coil pack.
    Mike
    • Like Like x 1
    • Agree Agree x 1
  12. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    Thanks for your help. It is really appreciated - everyones responses show what a great forum this really is. Hopefully as I live close to mwpe, I can take him up on his offer of using his code reader.
    Hopefully it isn't anything too problematic and I can find out what it is
    • Like Like x 2
    • Agree Agree x 1
  13. GazHyde
    Dec 2, 2011
    15,457
    9,814
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Thanks for clarifying Mike!
    • Like Like x 2
  14. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    Hmmm yeah it does seem different to that. It really is limping around with no acceleration so it does't seem to be the same issue/a cracked manifold if that is the case. Hopefully if it is a sensor or a coil pack it should be a reasonably cheap fix.
  15. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    This is great - thank you. Didn't read about the induction hoses so will take a look online about costs if that is the case. Definitely going to code read it first of course as this is clearly the first port of call. Even if it isn't the manifolds now - it is good to know that it is a known issue that I can keep an eye out for/be aware of so thank you
  16. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    T
    Thank you for doing that for me - this is really kind of you to do. The help I have got from everyone so far is fantastic :thumbsup::)
    • Like Like x 1
  17. EnthuZiaZT
    Dec 6, 2011
    4,690
    2,264
    193
    Heacham Norfolk
    Model of Z:
    Z4 28i Msport
    Just a thought, have you checked the air ducting between the filter and the maf unit, is it still attached.
    Mike
    • Thank You! Thank You! x 1
  18. t-tony
    36,643
    16,891
    Model of Z:
    Z4 3.0 Auto
    To be honest Matt, if it had been a cracked exhaust manifold, you would have heard a different note of engine noise anyhow.
    • Like Like x 1
  19. EnthuZiaZT
    Dec 6, 2011
    4,690
    2,264
    193
    Heacham Norfolk
    Model of Z:
    Z4 28i Msport
    To be quite honest @t-tony I could not hear any noise from mine. These engines have stainless steel manifolds, as the engine moves in relation to the exhaust, which is held rigid by a bracket underneath the car, the metal stresses. Small stress cracks start to form drawing in air. The extra air in the manifold upsets the lambda censor and triggers the engine management light to show on the dash. On the six pots the manifolds are made of cast iron.
    • Like Like x 2
  20. ZedLeppelin
    Feb 12, 2016
    35
    45
    32
    Nottinghamshire
    Model of Z:
    2.0l E85
    Thanks for this!
    I have just been to check (albeit with an iPhone torch) - I can't see that it has come off. It all looks in tact to my untrained eye! Nothing in the engine bay area looks amiss to me. I can't see any cracks in any hosing either but it is dark.
