Z
zedonist
Guest
Bolts yes, but you will replace them, flanges and pressed steel no, as they are mild steel so no transformation until after 900 degrees.Just a quick question, coming from the oil & gas biz, I know that above is done all the time but does it not change the mechanical properties of the material, as 'heat treatment' will harden the material.
