New Brake discs required
peteslag
Shifnal, Shropshire
Z4 3.0
That is VERY cheap for a set of drilled and grooved discs and the fact that there is no brand name is a bit worrying. To be honest, I would go for standard discs in this sort of price range.
Zed Carer
Pontefract
Z3 2.8
They do look very cheap - possibly (probably?) from Malaysia? I did quite a bit of research when I changed mine 3 years ago and finally found some Mintex grooved discs and slightly harder pads from Germany - IIRC they were around £200 for all 4 discs and the pads.
billz
Langley Mill
I bought some drilled and grooved discs off ebay at £89 for the fronts, they came from Birmingham too. Although a different seller. i have just had to replace them as they had worn away in only 8000 miles. I have now fitted brembo discs not cheap but i am hoping they will last longer than a year.
bill
swamper
Bacup
M
bill
lets be honest tho bill you do give them some stick...most people would have them for years if they just used them for "normal" road use ;)
r37
when it comes to brakes i wouldnt scrimp. You can get a good set of drilled + slotted disks for under £200 a pair. Drilled disks are known to crack which could be entertaining if you dont keep an eye on them and the benefits arnt massive over slotted disks alone. EBC and Black diamond disks are very well liked amongst car entusiasts as are EBC or mintex pads. I looked at upgrading my front brakes and IIRC a set of BD slotted disks and EBC redstuff v2 pads was a score over £200. Mintex pads are aparantly better but are allmost double the price of EBC reds.
billz
Langley Mill
swamper said:
bill
They may get a little stick on the cruises :D but thats only around 6 runs a year, But you still wouldnt expect the grooves to wear flat in a year. :D
bill
peteslag
Shifnal, Shropshire
Z4 3.0
r37 said:
Drilled disks are known to crack which could be entertaining if you dont keep an eye on them .
I have heard this too, especialy with cheap discs. :-q
z3cade
East Anglian Crew
Peterborough
Just go for a set of standard oem disks mike..
Brand like mintex or brembo as said.
Better not to go for cheap when it come to brakes..
:coolsteer)
Cheap disks tend to worp..
EnthuZiaZT
East Anglian Crew
Heacham Norfolk
Z4 28i Msport
Thanks Guys, I'll keep looking and keep you informed. 8-x
board
Administrator
Staff member
Administrator
Global Moderator
Lincolnshire
M Roadster
If you're not heading on to the track I'd go for the OEM option. You should be able to get a reasonable price with the discounts from the dealer to make them reasonable.
yocky z3 2.0
Cudworth barnsley
Z3 2.0 roadster
Hi mike i have mintex discs & pads all round been on a few cruies given them some stick and they have been great not that expensive ether on ebay cheers tony.
ginettaman
Fitting these tomorrow from carparts 4 less
Pagid Brake Disc (Front) Part No.: 104110028 £23.40 each
Blurb on carparts 4 less site:
Pagid has a strong history and earned its reputation with vehicle manufacturers like VW Group, DaimlerChrysler, Opel/Saab and Porsche.
Through the years a philosophy of quality and performance has ensured Pagid has evolved into the choice of vehicle manufacturers globally.
Pagid's reputation for high performance friction is substantiated by O.E. approvals with:
Audi S4, S6, RS 6, TT, Q7
Mercedes C-Class, SLR
Opel Vectra OPC
Lamborghini Murcielago
Aston Martin Vanquish
VW Phaeton, Touareg
Porsche 997 GT3 RS, Cayenne
B
badman gee
Guest
most of you olduns drive round like miss daisy, so stick to oem :p
EnthuZiaZT
East Anglian Crew
Heacham Norfolk
Z4 28i Msport
Oye you, :-o we wear out our discs out, holding back whilst waiting for you to change into second gear, to make sure you catch up and don't get lost on our cruises. :ymdevil:
B
badman gee
Guest
:D ;)
EnthuZiaZT
East Anglian Crew
Heacham Norfolk
Z4 28i Msport
spurs fan in a coupe said:
A bit too late I know but these are available.
OEM BMW £45 a pair delivered.
Does anyone know if 1.9 right through to 3.0 really have the same rear discs?
http://www.ebay.co.uk/itm/BMW-Z3-DISC-B ... _696wt_954
Thanks for the info, 'SFIAC', it's not too late, as I still haven't found any yet, unfortunately though, just the wrong end of the car, I'm after front discs. but welcome any suggestions Guys. :-bd
peteslag
Shifnal, Shropshire
Z4 3.0
Opel Vectra OPC
VW Phaeton, Touareg
I would pay some attention to this recommendation from ginettaman, Pagid brake components are superb for the money :-bd
