New Struts & Shock=Need Alignment?
PapaRoe
As the the title states, I just replace the rear shocks, and front struts on my Z4, with 97k on the clock. The car drives well, and doesn’t seem to pull to one side or the other. Should I get an alignment?
If you changed front struts you definitely need a steering geometry check.
Andyboy
SHEFFIELD
No. You are not altering anything on the steering or suspension geometry because the strut position is fixed both top and bottom.
Save your money!
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
At a lot of garages It costs nothing to check, they only charge if they have to adjust it.
Best to go at 10 minutes to closing time then ...................................... ;)=))
