Postie has been
Topperz
Swadlincote / ashby de la zouch
Z3 cosmos black ltd edition
so I can turn zebedee back to factory spec if the M\\\ police catch me ........wouldent want to be branded as an M wa***r again
How big is your letterbox?
mine must be slightly different, there 18. cant remember the width but they have 225 on the front with 245 or 255 at the rear, yes they do look good, didnt know they were fitted from new. i think yours look a little dished inwards so mine are not exactly the same
Great looking wheels :p
If you look around style 32 were fitted to loads of zeds as standard ....lots of coupes had them as standard as did the 3.0 roadster,
Mine is a z3 cosmos black edition individual ...they do look good IMO
i still cant figure it, topperz wheels still look slightly different to mine, maybe there just cleaner. after looking on the wheel fitment site im now wondering if i need spacers:rolleyes:
The rears are wider than the front on mine,also mine has the sports suspension option from new so it sits a little lower
This is mine sitting on 8x18" et35 offset with 20mm spacers on the rear if that helps
spacers eh, since i fitted mine the gap between the top of the wheel and the arch seems much larger, it isnt because overall there the same size as my previous wheel/tyre combo, its just an illusion. if i used larger (wider tyres) do i need to adjust the off set accordingly?
Spot on mate, you just cant teach the Welsh anything....;)
They're Just adapting to having different needs! Don't want the sheep slipping of the boot so found the solution! Found it too hard fitting sheep into the suitcase to use it properly, I'd guess! JIM
