Real OEM experts…..
AntStark
Hampshire
2002 3.0 Sport
…..got a challenge for you. Can you find me the part number for this rubber bung (Z3 facelift). There are two of them that attach to the underside of the car and stop the spare wheel bouncing about in its cradle ..thank you 😁
Item No.5. Emergency wheel bump stop. 2 off.
....and...BMW says no... "part no longer available"... and no old stock in the country.
AntStark, bombur - Iam just about to order 2 of these, I can order an additional 4 (2 each if you still require them). However, I will not be back in the UK to post them until December, if your happy to wait until then. They are Euro 3.61 each plus of course UK P&P to your address. I have added the link should you wish to buy direct. Having recently sent some extended Torx screws back to the UK the Postage from Germany was pretty steep.
There seems to be 2 different sizes depending on what size spare you have. Mine has a 16” wheel so the bump stops are much larger than the 15” ones
There are 2 part numbers for the bump stop in real OEM but I have no idea which is which 😁
Aren't the emergency spare wheels all the same size? Okay, just done a search and there are 2 sizes of wheel 15 and 16. I will contact both BMW sales to see what they say.
If they have the larger ones for the 16” wheel I would be interested
