- Oct 26, 2014
- Model of Z
- Z4 coupe sport.
A petrol head friend noticed the shut line on my Z4 coupe e 86 rear bumper near side was not as close as the offside so asked me if he could lift it by hand to see if the gap would close. It did close up which pointed to the fact that it had probably suffered a slight bump breaking the support bracket. Didn’t want dismantle without spare part in case we couldn’t get it back together. Spare obtained and should have been a straightforward swap but as usual with motors something else was also broken.
This is the broken bracket.
Three locating lugs broken plus the bracket Brocken in half. Should have been a straight swop but the rear light inner shroud has a locating lug which actually holds the bracket onto the the upper part of body wing.
All important lug broken off. So now with no way of getting new rear light shroud out of hrs or Sunday I decided to have a go at repairing it. First find a piece of decent strength plastic.
Thank you old number plate, super glue and tiny nut and bolt. Now even stronger than original.
schroud now bolted back in place with home made lug and fingers crossed bracket will go back giving us better shut line.
old one on right with brocken lugs
Now we have acceptable shut line on right side of rear bumper, feels reaffirm and can’t close shut line lifting it up from underneath. Took much longer than anticipated. (what’s new)
“Jobs a good un.”
RHA,ROY.
“Jobs a good un.”
RHA,ROY.
