Replacing HID headlights
Chaz Ricorn
Z4 3.0Si Sport
I've been reading up about the HID lights on my E85, as I find that even though it has HID lights the vision is poor.
I've found these which seem to be good and as I've used Osram Night Breakers before and found them very good. However I keep reading warnings about "only and expert should change these"
So the question is is this something I can do myself ?
Osram Night Breaker Laser D2S Xenon Single Box
https://www.eurocarparts.com/p/osra...IRU7SPSpv0Gv0024nV-_6geVONvYDuuUaAiZCEALw_wcB
jl-c
firstly, you realise that you will need two of these. Sorry, had to ask, better safe than sorry! If you can change a normal bulb you can change these. Just be methodical and do not touch the glass part of the bulb, only the base bit. Remove old one then reverse the process, simples!
Chaz Ricorn
Z4 3.0Si Sport
Cheers, all done, not a startling difference but a definite improvement.
