rmoconnor41
- May 25, 2021
- Model of Z
- 2.8
Run the data logs and we'll do an evidence based diagnostic.
tthanks. WeSnippet off the net
A noisy Idle Air Control (IAC) valve, often described as a humming, buzzing, or clicking sound, can indicate a problem with the valve's function, potentially leading to issues like fluctuating idle, hard starting, or stalling.
Had a similar issue with mine hunting like that when I first got it, but I did that, the DISA, and found a vac leak all at the same time, so I,m still unsure of which one was causing it or even if all were contributing.. But the problem disappeared...
Snippet off the net
