Space saver...jack....and...?!
FlashAir
Too soon old and too late smart
West Berkshire
3.0i SE (Auto....for the Missus!)
Hi all,
So, after getting on top of my Zed and sorting coolant and oil leak issues (all good...), the car has a list of things I want to do (machine polish, engine mod's, wheels, springs, MAYBE exhaust etc etc...), which I can justify as I got it Cheap Cheep (like the budgie).
It came with a space saver, in the boot in a bag (it also came with an AA compressor, the sat nav disc and 6 "Rave" discs in the auto changer...which sound great with the awesome stereo lol), however...there is no jack.
I reckon the previous owner may have had run flats on it, with bigger wheels maybe? There is no "proper" home for the space saver and like I said, no jack....whats the best thing to do? Is there proper place for the Space Saver (the bin, isn't an option!!). If i use the car on a work day, I CANNOT, not make it to work and so want to keep the spare and will need a jack too. What do you guys do? I won't put it on run flat 19's....roads are too crap and the ride is too hard (my M on 19's was shocking....but my other M on 18's was a great improvement....mostly down to run flats and the other, not!
Thanks for your thoughts....if i made any sense?!
FlashAir
West Berkshire
Brilliant....thanks for this......
FlashAir
West Berkshire
Hang on.....I think you're talking Z3?! Z4, to my knowledge has zero space for a spare. Annoying!!! So, looks like I will need to always carry the space saver (certainly for longer, critical journeys)?!
FlashAir
West Berkshire
Swat I figured :(
Anyone know if the 16" space saver first the 2004MY 3.0litre?
To be honest even on non run flat tyres you will be ok with a can of Tyreweld and a cig. lighter socket powered compressor. That's all I carry.
You don't need to carry a jack.
ps. If you get told that using Tyreweld or the like renders a tyre useless afterwards, disagree and get it cleaned and plugged as normal.
Eh @hard top ?
mrscalex
3rd Party Trader
Swindon & Swansea
The Tyreweld should actually re-inflate the tyre to some extent as well. But just as well to carry a compressor.
As long as the hole isn't in the sidewall it does a great job. And to be fair sidewall holes are beyond proper repair anyway.
If you see a screw or similar in the tyre the advice is normally to push it further in rather than remove it.
Personally I liked the system on my Alhambra. That used Contiseals. They have the gunge pre-built into the tyre ready for a puncture. But I don't think they come in Z3 size.
You can also get the gunge retro-fitted into any other tyre. Either by a specialist or DIY.
roadvoyager1
Shotley Bridge
2.8ltr
Ooops sorry, yes my comments are about the Z3.
You will just have to buy a Z3 for those longer journeys so you won't need to carry a spare wheel in the boot of your Z4.
The need for a 12v compressor comes down to the size tyre mainly, but also the size of the tin of Tyreweld. Check tyre size comparability on tin.
mrscalex
3rd Party Trader
Swindon & Swansea
The 2 times I've used Tyreweld it actually went from being almost flat to over-inflated. So maybe 10 psi to 40-45 psi. Well that's my recollection. But I have no idea how it managed it from a small can like that. It was the correct larger size for the tyre though. Tony is right to highlight that as there are 2 possibly 3 sizes of Tyreweld.
FlashAir
West Berkshire
So....is the 16" compatible on my 3.0 litre?
