throttle
katkwak
Hucknall / Nottinham
1.9 m44
seems ive got a sticking throttle will see if i can free it or buy new cable
is this a common problem
also my drivers window as started to act up if i drop it down a little is will only go back up a bit unless i take it all the way down then back up
Both zeds I have owned have always had a stiff accelerator and you can free them up with some WD40 or similar sprayed down the cable. I did this and it started to go stiff again so I replaced the cable which made it better, not perfect but certainly better. The 2.8 I have now has a very stiff accelerator, doesn't stick but is a bit of a pain so I picked up a new cable last week from the dealers which was only £17.54 so not expensive to replace.
  • Like
Reactions: Lee
It probably needs a new cable by now anyway, made a huge difference on mine but Also check the routing of the throttle cable - it makes a few turns and if it a bit too tight in one place it makes it stiff.
Re drivers window, get some silicon spray and lubricate the rubber slides as you work the window up and down.
