Welcome to ZRoadster.org - BMW Z1 Z4 Z8 Z3 Forum and Technical Database
If you want to join in with the discussion, and see the areas which are available only to members then sign up now!
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Vanos solenoid and check valves.
Discussion in 'Z4 Roadster & Coupé' started by Rha, Dec 22, 2019.
  1. Rha
    Rha Zorg Guru (V)
    Supporter British Zeds
    Oct 26, 2014
    3,578
    2,986
    175
    Hemel Hempstead, Hertfordshire, England.
    Model of Z:
    Z4 coupe sport.
    Just as a matter of interest I checked my Vanos solenoids and non return valves yesterday as the weather warmed up a little and it stopped raining for a couple of hrs.
    After getting an accelerator flat spot and idle surge I looked on the internet for advice and was amazed at what could be causing it ie Vanos,maf,Disa etc. Out with my Delphi scanner and only fault was maf 2D06 to my relief. Carb cleaner and job done 20mins later I was bored so decided to have a look at the Vanos solenoids as I had already purchased them a week earlier. This was a very fiddly job indeed and thanked god for giving me small hands as even with the rad top cover removed there was barely room to get them out. They were absolutely pristine looking but changed them anyway for peace of mind. Now looking at the area where the check valves are situated I was thinking I should be able to get to them without removing the wheel and inner arch cover. So armed myself with extending lighted mirror and T40 taped onto a 3/8extension bar I found removing the washer bottle gave me more room. Bit of a struggle locating the T40 into the check valve as never really used mirror for much in the past, can’t believe how my reactions were completely off target upside down wrong way round right instead of left etc. After half 1/2 hr I was getting the feel of it but it wasn’t easy. Valves were like new so carb cleaner used just to make sure. Here’s a pic of both vales and solenoids just as they came out. Looks like I could have used my time better but at least I now know they should be ok for a while. No check engine light now but needs a run out.
    B1B55CF2-6DE0-45E6-95BE-72BF1E8DC9E7.jpeg b
    Think I can safely assume that if they’ve been in for any length of time the oils been changed frequently on this Z4coupe e86 n52 I know previous owner @Lee done a lot of preventative maintenance which makes me feel I should maybe just leave it alone. Anyway it’s always good have a look see, makes for more confidence in a motor. No???
    (Love this car even when the suns out.)
    RHA,ROY.
    #1 Rha, Dec 22, 2019
    • Like Like x 3
  2. Lee
    Lee Zorg Guru (V)
    British Zeds #ZedShed M Power
    Mar 26, 2014
    3,433
    4,310
    193
    Basingstoke
    Model of Z:
    Z3 Roadie 3.0
    Nice. I did just this about 5 years ago :)
    Has your flat spot gone ?
  3. Rha
    Rha Zorg Guru (V)
    Oct 26, 2014
    3,578
    2,986
    175
    Model of Z:
    Z4 coupe sport.
    Yep no trace of hesitation at all Lee, just done 30mls and if anything the coupe is even more sensitive on the loud peddle. (and no I didn't have it in sport :)).Nearly kangaroo'd it twice.Picks up better in 6th, definite slight improvement. Needle doesn't waver on tickover. Was it the MAF or the vanos solenoids/check valves.????
    Who cares it's going great.=))
    Roy;)
    PS; Couldn't wish for a better Christmas present.:thumbsup: Oh Oh the wife's just seen this so of course her present of a front and rear dash cam fitted at Halfords is obviously the best.=)).
    • Funny Funny x 2
  4. t-tony
    t-tony Zorg Expert (II)
    Supporter British Zeds #ZedShed
    36,644
    16,891
    Model of Z:
    Z4 3.0 Auto
    Ready a decent road test mid to late Jan. 2020?;)
    • Funny Funny x 1
  5. Rha
    Rha Zorg Guru (V)
    Oct 26, 2014
    3,578
    2,986
    175
    Model of Z:
    Z4 coupe sport.
    Might need some snow tyres then?????:eek:
    Roy;)
    • Funny Funny x 1
