Took the Zed (Z4 3.0SI N52 engine) into work this morning only to hear a nasty whining noise from the engine when I got there. It wasn't there when I started but very distinctive when I arrived. No lights on the dash. No loss of power etc. No checked for any codes yet. My initial fears were VANOS, but its not quite in the right place.
No noise when I started the engine this evening, but, by the time I got home the noise was back.
However, it isn't a constant whine.
Cold - whatever engine revs : No noise
Hot - at idle : No noise
Hot any other revs : the noise starts but appears at a constant note irrespective of revs and disappears again as soon as the revs drop to idle. It is coming from the oil cooler area. Is the oil filter in there too?
A quick search indicates that theres nothing rotating in there that could cause what sounds like a bearing noise. Straight off out this evening - I'll have a proper listen with a screw driver to properly isolate the whine tomorrow when I get chance.
Some suggestions are its a deformed oil filter or some other constriction.
Anybody any thoughts or ideas.
The nearest place I could get to look at it is by work - 27 miles. I'm hoping its still ok to drive.
