Will these alloys fit my Z4?
Lytesben
South Somerset
Hello,
New Z4 owner here. My car currently has some 16" alloys fitted and just think they look too small.
I have seen a few sets of the M Sport alloy wheels and not sure whether they will fit my Z4.
https://www.ebay.co.uk/itm/322447213159
Anyone able to advise?
Dependant on the offset, they will fit as the PCD is the same. Personally I wouldn't go to 18" if they're on run flats, if you plan on using standard tyres I would. I'm on 18" Goodyear F1 Eagle tyres.
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Yes, they should be ok.
GazHyde
Administrator
Administrator
Global Moderator
Berkshire
Z4 MR
If they are genuine and a 3 series fitment you should be fine. Will likely need spacers on them but then the Z4 arches are pretty deep and standard wheels need them anyway.
Easiest way to check fitment is to find your current wheels on http://www.bmwstylewheels.com/ then compare the offsets and widths against your own (that's assuming you have standard wheels, if not compare against the 107 or 108's). You can also use the offset calculator on http://www.1010tires.com/Tools/Wheel-Offset-Calculator to visualise the differences as well.
