Will these fit?
Antm72
South Yorkshire
Been looking at suspension upgrades have read that the E36 compact suspension is a it for the zed is this correct?
Found these
Will see if they have for a zed but price seems good with all mounts included 8kg springs all round.
Any input appreciated
Thanks Ant
Are those adjustable damping knobs on top of the struts?
What brand is that, can't quite make out.
8kg should be good.
Don't know if it will fit though..
It says 24 levels of damping adjustment so yeah must be i will contact them and see if they can supply for a zed
I'll be a little controversial here and if your not lowering your suspension for looks and your standard springs and shocks are fine don't bother.I would do the bushes though.if you enjoy track days or competition definitely, but spend a bit more and get some quality items.just from personal experience standard is great for touring and everyday driving,and you can drive pretty quickly as is,any faster and your living on the edge.
i'd like a slightly lower look just for stance in all fairness the shocks are new allround on the zed and the suspension seems ok.
Have looked at H&R springs and eibach and possibly retaining the standard damping as said they are ok and at 25mm i should still have travel in the shocks but i suppose uprating them too will give me the extra travel in dampers giving a better ride.
Coilovers as you say start cheap about 150 and if i remember rightly i fitted said set to my last zed and as most say no real rear gain in height to stock i think i fitted a rear set of springs from an e36 cabriolet in the end and it dropped the rear end nicely.
Its quite a mine field i suppose and looking to do it once without ruining the zeds driving pleasure but i would like to loose abit of the wheel arch distance without going daft.
