Yeah I did mine took old ones off put new on
Pretty simple support the trailing arm unbolt shock with 18mm socket,
pull carpet back behind seats undo two 13mm bolt heads and should drop out.
The bolt holding the mount on can be undone whilst holding the thread with an allen key. Failing that get the mole grips out. Installation is reverse.
