1998 Z3 1.9l Autocross Build
Randall M
Davis, CA USA
Z3
Getting started! 1.9l M44, 5-speed, 102k miles.
Getting it ready to run in E Stock. I autocrossed a lot in the Denver area about 40 years ago. Life has circled around, so I am at it again, soon, in the Sacramento area.
Removing weight...glove box anchor weight; spare tire, holder & bin. Fixed seat rail issue, seatbelt guide fixes, misc. fixes to tidy up for the first run in maybe August.
Randall M
Davis, CA USA
Z3
Changing out a leaking oil tower, today. Changing the filter and pressure switch while I am at it.
Randall M
Davis, CA USA
Z3
Last week, I added a new steering wheel cover from https://stitchingcover.com/. I wanted a bit more diameter/grip and a fun color (nearly matches BMW blue). Took about 2.5 hours total. Great quality...the vendor was very careful to match my wheel with several BMW wheel styles.
And seat covers... and wind deflector.
Shelly
East Anglian Crew
Norfolk
Z4 2.0 20i M Sport sDrive
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Welcome from Mansfield UK. Going to be an interesting thread.
FLZ_Boy
American Zeds
Texas
Z3 1.9L
I do look forward on your build. If you do go beyond E Stock, there are a few things you can grab from the higher trim Z3 models: bigger front brakes+rotors and rear differential with LSD options. I haven't sat down to read all the compatibility on rear differentials, but based on my various searches you can find what you need. I do recall someone running the smaller 1.9L calipers and rotors and brake fade was problematic on aggressive track days. Hope that helps!
Mint
East Anglian Crew
Stafford
2.2 Sport Individual
:welcome: again and looking forward to seeing your build.
Randall M
Davis, CA USA
Z3
I have a replacement shift boot aching to go on, but I CANNOT get my shift knob off. Tried brute force, tried levering it upward with a Crescent wrench and pipe, not a budge. Gonna have to cut it off and get a new one.
Randall M
Davis, CA USA
Z3
Busted it off with sharp diagonal cutters (just kept nibbling away at the plastic). New knob tomorrow.
Randall M
Davis, CA USA
Z3
Headlamp restoration today using a 3M Ultra Headlight Restoration Kit.
Results are great. Was able to do both lamps with one kit. Did a triple coat of the sealant. Make sure you tape off well. I did scuff a very small spot that will need to be buffed out. Otherwise...easy peasy.
ktnez99
West Midlands
Z3 2.8L
Hello and welcome. Looks interesting. You’re in the right place for help, advice and banter.
