Gotcha. I had installed a 28mm H&R on the softest setting on the front, and a used rear bar from a 1999 M Coupe that's 4mm thicker than what mine came with for my last AutoX, and while it certainly rolls less, my shocks and tire pressures were NOT set up well to accommodate them and I felt like understeering was a problem.
I have another AutoX in two weeks, and I'll try different shock adjustments and tire pressures and see how the understeering is. If I tame it, I would love to set the fronts even stiffer...
