That's interesting. Does that mean I could potentially easily change front 3.0l calipers and discs for, say, 2.8l items? I was under the impression that the 'free litre' has larger diameter discs and calipers.Just before i go hunting for a carrier to measure this why do you need the measurements.
All z3 1.9 - 3.0 and e36 and e46 have the same bolts hole spacing irrespective of the disc size ( carriers are different sizes to match disc but mounting holes the ssme )
Stephen.
Hi
Could someone confirm the distance of the mounting holes for the caliper brackets please?
I have the calipers already and 17"wheels,so will be rude not to. Probably go to 300mm discs nothing bigger. Having the bracket size will give me a little bit of a head start.122mm CtoC if I remember, I can check on Saturday.
You’ll find both 121.7 and 122.5mm quoted on the web if you search long enough. Both those figures are converted from Imperial (I think).
Why though? Alloy bells will give a better unsprung weight reduction than Wilwood calipers.
300mm discs is dead easy, as above, max with BMW parts is 325mm, afik anyway, big increase in swept area, again bolt on and cheap, but needs 17’s.
Thanks for the guidance ,I've made some before but for bikes not cars. I'm not really a car guy but I have to say bikes are so much easier lolIt’s more that I have health problems than anything else, can’t take on yet another project when I haven’t finished the 50 or so I’m doing.
Do the designing off the car, it’s much easier, just get a hub from one of the breakers, cheap, no use to anyone. Fit them in an afternoon then.
Don’t watch the YouTube videos, some on them are downright dangerous, welding to cast uprights etc.
Wilwood themselves do quite a good guide on how to make a bracket.
Simplest way is to plan it from the caliper to the upright, not the other way around. If you use ali, inserts are a good way to go if anyone other than you works on the car.
