- Nov 25, 2012
- Location
- Newport, South Wales,UK
- Model of Z
You need to relocate the pump/motor from the well it sits in into the trunk so you can see what's going on with theanual release valve on the pump housing, I suspect its seized. A few light taps with a small hammer and some lube will free it up so the hydraulic pressure is reduced to allow the roof to be raised. Check out the cable action is then working when the red ring is pulled and locked.
Finally relocate the unit in the recess in the left side of the trunk check the oil level in it.
