3rd brake light bowing
elevensies
North Lincolnshire
roadster 2.8 widebody
took apart 3rd break light to replace a few of the bulb and twist holders, i ordered a new outer O ring, and putting it all back which needs 3 hands to don iv developed a bowing in the middle of the outer red part....
there doesnt seem to be anything obvious iv done wrong....but clearly i have, as the outer red part doesnt really sit well.
any ideas please.
A photo or two may help.
Hard to see but I can press in the middle and springs back, there's about 5mm movement I guess
You might be able to heat it and bend it back, not sure but heat did this and heat might be a fix.
Otherwise Bimmerworld and Pelican parts offer replacement lenses, they are not cheap but if you break it trying to fix it....
I sussed it , the new seal I bought wasn't sitting in the right llade , hard to see when your looking upwards.. anyway stripped ot all back out , re positioned it , and it all went together as should .
What a pita tho,
