rmoconnor41
- May 25, 2021
- Model of Z
- 2.8
Sold
I could feel the solenoid (top one) clicking today @Lee ..it’s very audible. Looks easy to get it off but is it at all serviceable/cleanable or is a new one needed ?What was the outcome with Iridium Rich ?
Did they have the car cold to look at ?
If you can hear a rattle around the vanos as said above it might very well be one of the solenoids getting sticky.
Best to replace, they fail internally.
Not sure on their cost. Ones easy to reach with a 32mm spanner the other needs a crows
Febi one on eBay for £46.50
Part 175323 ..says it The exhaust side solenoid is blisteringly hot after the car has been driven. Switched out the inlet side cam sensor but not the exhaust side.
SoldMine was rebuilt a few years ago and developed a ticking. It was the camshaft sensor failing. Replaced that (£22) and the noise went. This was last month and been fine since
You can test them with a multimeter and check the ohmsWhether it is cam sensor or the other solenoid, I need @AntStark on the case with me.
