Recently changed my rear lights over to clears and when i put them all back on and tested them thought i had bulbs out!
The rear tail lights are quite small and thought it may be a good mod to light the brake light section of the light as a side light too to give a better lighting result at the rear.
Decided the easiest way to do this was to change the internals of the bulb holder to a twin connection so i could use the brake light section of the light for both the functions
So a picture of the rear as standard ( no the best picture but you get the idea)
So got the parts ordered bulbs and the holders and after a bit of rewiring got this.... .
And with brake lights....
What do you think? im quite pleased simple to do for under a tenner and that bit more rear end light coming into winter..
