Another crank, no start.
WOW! What a response.
They say the most valuable gift you can give is your time so a very big thank you to you Murry.
You definitely deserve that beer. Just wish there was someway for me to buy it.
This will probably take a while for me to sift through but I will print it out and go over step by step.
Your time will not be in vain and I will report back soon i hope.
Following! I have a very similar scenario with my new to me 1.8 1996 (Aug. build EWS2) M43 Z3.
Hi OscarS
Welcome to the forum.
You will find a lot of info and knowledgeable members here.
Hopefully this thread will have given you some ideas and possible avenues to follow.
I have checked out most of Murry's last post and all seems good (will double check just to be sure).
Am trying to get the BMW Scanner working to interrogate EWS2 further but having trouble with the computer drivers.
Not had much time with Christmas fast approaching but will update soon.
Well hello! Got me a '99 coupe here in the US and I'm having similar issues. I'm still working through the troubleshooting advice in this thread (very informative!), but I figured I'd revive the thread now hoping OP found resolution (for his sanity, and mine). TIA!
Here is another resource for you: https://www.e46fanatics.com/threads/e46-no-start-–-list-of-possible-causes.1011677/
While it is for the E46, the concepts are all the same on your E36/8
Thanks for the reply. I've been scouring E36-E46 threads and documents for the last couple weeks. But in my case, I found the issue, and it's kind of a DUH moment. I'll recap in case it helps someone else in the future ('99 NA coupe with m52b28tu).
tl;dr: It was a blown fuse 26 the whole time...charts and diagrams are misleading.
My coupe was molested by the previous 6+ owners, so I knew it was unique when I bought it. I took out the center console to troubleshoot and eventually revamp 90% of the stereo system. After driving around for a year with the center console removed, my buddy and I reinstalled it...and bam! Strong crank, no start. There was no indication of issues with running prior to this. Here's what the cluster looked like:
This is where I started to chase symptoms instead of the problem. The tach didn't bounce when I tried to start it, so I immediately thought CPS. Swapped one in, still no start. So the temp gauge pegging right made me think faulty temp sensor cueing the DME to not start the car when it was "overheating". It was about this time that I started swapping fuses too. I pulled every fuse and swapped all of the "relevant" ones (FP wasn't priming, couldn't communicate with DME through 16 or 20-pin...), but I didn't find anything blown. I tested power to FP and all "relevant" relays and verified power to fuses but not at FP relay or FP itself. Checked fusible link, and it was good too. Had power to non essentials like lights, seats, windows, etc.
Swapped the coolant temp sensor, tried another CPS, still no go. I was suspecting DME corruption for some reason without a hint to causation (maybe shorting something with the console reinstall...). I began pursuing the no comms with DME hoping that I could get a resolve so I could get codes. In doing so, I found this thread talking about fuse 26 controlling the 20-pin. On my fuse box it says 26 is ABS/ASC and I had no indication those things weren't working. On the wiring diagram, it shows DME and DataLink along with other things like cruise control interface (ASC) and reverse light (plus some other little things). Anywho, rechecked that fuse and sure as sh!t it was blown. Replaced it, fired right up, and now I can communicate with the DME on both 20-pin and 16-pin.
I think the logic is that if your ABS isn't working, what better way to notify you than to disable the car...but IMO it should disable the car while still retaining the communication to the DME so codes can be pulled. Don't know the cause of the fuse blowing (yet) but I swapped my original CPS back in and it still fires. Going for a drive today! Hope this helps someone...
Just a quick update seeing as this has made it to the front page again....
Car is still sat in the garage with no progress made.
Managed to get the BMW Scanner working (thanks NZ00Z3 - Works a treat) but this too states all is well.
So thats x3 BMW specific scanners!
Looks like I'm going to have to strip this down a bit further than expected......
Sorry to revive an old thread, but I just wanted to say thank you so much for this post. This is my first reply on this forum. I had the same exact problem as @raw.shu . I just bought my buddy’s z3 two days ago after it sat in his garage for 3 years because of this issue. He looked into everything including CAN bus. I went through the whole spark fuel DME diagnosis process today and yesterday until I found this thread. I really wouldn’t have looked at fuse 26 without this post. Thank you so so much everyone, these forum posts help people people like me so much.
Sorry to drag this back up again, but I've similar symptoms to the OP and wondered if this was ever resolved?
The car was running fine, but after a couple of years in storage it now won't start:- it cranks and has spark (runs on easystart) but has no pressure at the fuel rail.
This isn't too much of a surprise as the fuel pump isn't running, and so far I've found the following:
- The 5 fuses in the ECU box all get 12v with ign on (I think this meant the DME powers up ok)
- Fuse 18 in main underbonnet box has permanent 12v
- Fuse 13 gets 12v with ign on ( I think/guess/hope this means that the EWS is seeing the key and the DME is happy?)
The fuel pump relay does not click when ignition is switched on, but pin 30 has 12v and pin 86 has 12v with ign on. However, pin 85 (I expected this to be an DME switched earth) has 0v with ign off, but goes to +4.25v once ign on.
I assume this is why the relay does not attempt to energise, but sounds like one of the earlier posts in this thread - but I'm at a total loss to understand why this happens!!
(In addition, I'm fairly sure I also have a failed fuel pump as well - if I connect a jumper between pins 30 & 87 on the relay base you can't hear the pump run and there's no pressure at the rail).
Any thoughts or tips very much appreciated!!
Tom
