- Oct 19, 2014
- Model of Z
- 2.2i Sport
Fiddling around with the Z the other day, and remembered how some German cars in the past had parking lights worked by the indicator stalk. Sure enough, ignition off, indicator switch to right-hand side, and side and tail lamps come on. Only on the O/S, don't know if it's meant to work on both sides. Any one else noticed?
. You can set the parking light on either the off-side or the near-side by pushing the indicator stalk passed the normal indicating position against spring pressure. The stalk then returns to the left or right indicator position.
