In preparation for installing RaceLogic Traction Control on my 1998 M52B28 fitted with ASC (not DSC), I have removed the whole ASC butterfly valve assembly & fitted a smooth intake boot for better airflow and of coarse the 'ASC' light is on as expected.
My understanding is the the ASC operates by cutting the air take & apply the brakes.
My objective is for the ASC to do absolutely nothing & I have already achieved the first part of that by removing the valve assembly so it no longer effects the air intake. This is clear. No problem.
However, I was thinking about how to be sure that the ASC software is not applying the brakes (as I am told that it does) when the wheel sensors detect loss of traction? I am told the engine power can overcome the brakes, but obviously it is something I do not want to happen.
I now have the option of:
1. Removing the ASC bulb as it no longer functions (the ASC light is 'on' irrespective of pressing the ASC button since removing the ASC valve)
Question: Will the ASC system still apply the brakes when loss of traction even though the ASC light is always on? I think/hope it will not so I might as well just remove the ASC bulb?
or
2. Fitting a 20 ohm resistor to 'fool' the system that the ASC valve is still in place and operating normally
Question: presumably this will make the ASC light go out so the ASC will still apply the brakes on loss of traction (unless I press the ASC button so ASC light comes on to indicate the ASC system is off) ? I really do not want to have to remember to switch the ASC button every time I use the car
I think the bottom line is that when the ASC light is on for any reason (fault of any type or switched off by ASC button) the whole ASC system is disabled and no brakes are applied even when loss of traction?
Therefore, it seems the best solution is option 1 & just remove the ASC bulb ...& then connect the RaceLogic TC
Any comments/advice views most appreciated on what is the best way to achieve my objective of not having the brakes applied by ASC on loss of traction
Thanks all
or
Thanks all
and see if you can feel the brakes cutting in as it should be able to sense through your buttometer.
