Assume
give in buy a new battery and make sure you drive her more to keep charged :p
Stacey I would if I thought it needed changing, so cos everyone on here thinks I'm an old skin flint and won't buy one I'm going to leave booster in the house and see how long batt lasts, if it's still ok at the end of the summer you lot have lost,:) if not I'll go out buy new one plus make a donation to the .org fund. :bag: :happy:.
Regarding battery, here is a story you wouldn't believe:
When I bought my Zed from Germany on the car was an Energizer 9 years old!
(The US bat have written a very clear date of production, not a code like the UE made.)
For car battery which are not in a daily use , I put them on a charger every 30-45 days for 12-24 hours, according to the power level (when the Amps goes lower than 2.5 A and you can hear the "bubbles") the process is done.
I kept the Energizer for another two years on the Zed (11 years!! life time) and because I was afraid for an unexpected break down , during the summer trip, I replace it with another Energizer (US made too).
And I kept the habit to charge it every 30-45 days in Winter.:)
So some times the life time of a battery can be very short or very long!
What I can say is the charging system of the Zed is batt friendly and don't overload and damage the batt.;)
@Zeti, I have an even better one! I bought two vehicles from a farmer in Saskatchewan several years ago. A 56 Pontiac 6 cyl and a 68 chev impala with a V8. Both still had the original batteries in them.. The 56 had 68,000 mi and the other 49,000. I thought no way will they hold a charge but because I don't like to spend money I put them both on a slow charge for two days. Got into the Impala and the starter cranked over first crack. Got in the 56 and same thing so I poured a bit of gas in the carb, turned the key and the car started and idled on gas from 1968 when it was parked. The batteries were toast and wouldn't hold a charge but talk about the difference between old and new improved products. JIM
Hi Lee, your probably right I would,the whole thinking behind taking the booster round is to preserve the life of the batt, if I thought batt wasn't up to it I wouldn't think twice, I believe that the jumper takes the real wack on initial start after car has been sitting for a couple of days to a month, so surely if car batt is not getting trickle charged and only doing half the work to start cold it's got to help towards the life of car batt, as your better informed than me I was hoping you might be able to quantify. Am I really just giving my right bicep some exercise or is this pain in arse jumping really helping. :meh: If the answer is NO then I will get the Pos and the Neg of booster connected to my testicles and throw the switch.
Video at 10:00pm folks!! Will Roy jump start his car or his sex life??
I was just doing some reading on car batteries and saw this:
Car Battery Tip #1
If you plan to disconnect your car battery from your car, be sure you read your car owner’s manual! In most cases (unless otherwise stated in your manual) you will need to disconnect the negative cable first and then the positive cable. When you reconnect the battery you use the reverse order by connecting the positive cable first and then the negative cable. Doing this simple step incorrectly can have adverse affects on fuses and other electronics especially in Mercedes Benz and BMW type vehicles resulting in $$$ hundreds of dollars in repair. Even keeping the keys in the ignition when connecting or disconnecting may have negative effects so always read the manual.
You can also invest in a specialized 12v battery or specialty device that will maintain power to the electronics in your car so onboard computers, lighting, fuses and car radios do not get affected. Many things you wouldn’t think about are actually controlled by computers in cars. So read the Car Manual before attempting removal of your car battery.
Also saw this: (we already know most of it)
How to Extend the Life of Your Car Battery
by Josh Sadlier
With all the modern technology in cars these days, it’s easy to forget that we still depend on good old-fashioned lead-acid batteries for accessory power. But even if you haven’t forgotten, it’s not like you can do much about that mysterious black box other than wait for it to die in an inopportune moment. Right?
Wrong! In fact, there are some commonsense steps that everyone can take to care for their car batteries and help them reach their expected lifetime. Safety is a priority for us, so we’re talking simple stuff for normal drivers - let's avoid acid accidents, shall we? Here are 5 ways to make sure you’re doing right by your car battery.
1. Know thy battery.
Specifically, make sure you know when it was made and how long it’s likely to last.
Every car battery sold in the U.S. is stamped with the month and year of its manufacture. You’re looking for the first two characters in particular: a letter and a number. The letters, starting with “A,” correspond to months starting with January -- so “C,” for example, means March. The number is the last digit of the year, so “8” means 2008.
Sixty months (or about five years) from the born-on date is a rough estimate for normal battery life, but many factors can shift this figure one way or the other. Still, keep that date in mind if your battery starts to show signs of depletion, such as trouble starting the car or dimming lights. If the battery is relatively new, maybe you simply need to recharge it; but if it’s been around for a number of years, you might need a replacement soon.
2. Turn your lights off when you get home!
Probably the single most common cause of premature battery depletion is headlights and/or interior lights left on overnight, especially if you tend to be a regular culprit of this practice. Some newer cars have auto-off functionality, but most vehicles on the road still don’t, so it’s important to be vigilant here. Sometimes the chime or other warning to let you know your headlights are on can be hard to distinguish from other sounds, like the one when you open the door with the key in the ignition. If that’s the case, we suggest getting into the habit of checking your lights whenever you turn off your car. Don’t forget to check the dome lights as well. For the typical car battery, a single night with the lights on will have you begging for a jump-start in the morning.
3. Use accessories sparingly when the engine is off.
Modern alternators have no problem keeping the battery charged when the motor is running, but if the motor’s off, power-hungry cabin technology can do a number on your battery in short order. A battery without the engine is kind of like a laptop without its plug: you’re on borrowed time, and the more you run that battery down, the less eager it will be to hold a full charge. Accordingly, try to limit the amount of time you spend using powered accessories with the engine off. We know it’s tempting sometimes to leave your passengers in the car with music or a movie playing, but you probably shouldn’t make a habit of it.
Also, keep in mind that vehicle security systems are a constant drain on the battery when armed. As such, while it makes sense to arm the system in the shopping mall parking lot, it may not make sense to do so in your own garage, especially if you don’t drive the car every day. In low-risk situations, consider locking the car with the key instead to save your battery the trouble.
4. Monitor battery performance.
The best sign that your battery’s under the weather is slow “cranking” when you start your car. The usual cheery cranking noise will turn dull and lethargic; you might even find yourself wondering if the car’s going to start at all. The good news is that this doesn’t mean your battery is gone forever. You might be able to recharge it. But you shouldn’t knowingly leave your battery in a depleted state for more than a few days, because lead-acid batteries must constantly be kept near full charge to avoid a malady called “sulfated plates”.
So as soon as your car starts sounding sluggish when starting, either drive it around for a good 30 minutes – which should recharge the battery automatically – or take it to the shop and ask for the battery to be tested and recharged. Subsequently, keep an eye out for further symptoms, which would indicate a need for replacement. Consider it a normal part of car maintenance, just like checking your oil: your car needs plenty of oil to run properly, and it needs a charged battery, too.
5. Disconnect or “tend” the battery when parked long term.
If you know you won’t be using your car for a few weeks, it’s advisable to give your battery a rest, too, since a small amount of current continues to flow even if the security system isn’t armed. The old-school approach entails disconnecting the negative battery cable (typically marked by a big minus sign), which certainly helps but has the undesirable side-effect of wiping out all of your electronic settings. A better idea, if you can justify the expense, is to pick up an automatic battery charger, which maintains your battery’s charge and lets you keep all those settings, too.
Very funny Jim=)), but between me and you, do you really think I would volunteer to do such a thing without first trying it, for some unknown reason I didn't get an electric shock but what I did get was extremely painfull, you see I forgot just how powerfull the springs in the heavily cerated crocodile clips are, needless to say when the wife asked me why I was walking so awkwardly I had to tell her that I stepped on the metal part of my pick axe and the handle shot up hit me in the groin. So no jump start for my sex life,just quite the opposite.:wacky::wacky::wacky:
Ps; Gaz, I hope you consider this is still on topic and relevant.;) After all I wouldn't want anyone else making the same mistake.:nurse:
Your so lucky Jim to have so much space, I'd give my left testy for all that. Yes Jim, I would STILL have one left.;)
You have two lefties and no right!! Interesting, never heard of that before, except down in the southern states but that was inbreeding I think. Ever been to Alabama Roy? JIM
Oh I think we're gonna get spanked for these posts!! Rm 101 again!
