Badge Size Z3
Chamber66
Swansea
Z3 2.8
My car is with my paint sprayer 30 miles away so i cant measure. One of my side badges has broken.
Could someone confirm the size please?
TIA
:welcome:
Side 78mm
Aftermarket ones are available at 76mm and as there is only 1mm difference in overall size you don't notice this. I used this size on my Z3, and the pin spacing was different so I cut them off and stuck the badges on using 3M double sided tape.
Thaak you very much.
I would advise checking with BMW first, the last set I bought were slightly cheaper from them than online and the quality is much better.
And that's why I use aftermarket ones. I can't justify that amount. The bonnet and side gills aren't the same size though.
A complete rip off. Mine from Alibaba cost a fraction of that price. They won't last as long but look pretty good for two or three years. And probably a lot longer if you keep your car in a garage. Also I don't think bmw do them in black and white
