What size tyres are you running on the back ? I'm on 255/18
Mine are on 245/18 rear and 225/18 fronts. The fronts are sitting bang in line with the arches without spacers but I have a small roll on the tyre exposing the rim which I don't like but while I've got a good complete set of falcons on i'll live with it and address it when I'm due a tyre change.What size tyres are you running on the back ? I'm on 255/18
Ouch!!!!Found these, 100% sure you won't find anybody for a review, they're $395!!
http://www.rogueengineering.com/rogue/WH/RE-MEGA.html
Ash
I personally prefer them to bolt they seem to stabilize more easily on the wheel. JIMSo what are the thoughts on wheels studs and lugs instead of bolts. Can't see any drawbacks to this?
http://www.elite-d.co.uk/race-wheel-stud-conversion-kit-m12-x-1-5-bmw/
Glad to hear all ok Dave!Well I'm pleased to report the spacers have been on almost a week now. Done 200 miles over Thursday and Friday, re-torqued twice and no movement on the bolts at all. All appears to be sound.![]()
No none. But I don't drive hard to be fair and I have a chassis and strut brace so the car is very tight anyway.Glad to hear all ok Dave!
Did you notice any change in handling?
I don't believe there is any make of car sold in NA other than European imports that haven't got studs. This dates back to the modelT and every brand since 1903. And we also have hi tech wheels available as stock and aftermarket items just as in the UK. Never have I come across the problems you mention, this after owning many hundred cars used as well as new. But you need to do what you believe in and I can respect that. JIMJust looking at the studs and think they will chew up the bolt holes in the wheel as you slide the wheel on and off thus chipping the paint and letting corrosion take over...so no good for us 'fancy wheels' types, especially after mine get a refurb...
Will stick with he BMW alignment pin and bolts...
Really like the studs though especially with these extended nuts from Hack engineering:
http://www.hackengineering.co.uk/product/mh-titan-cold-forged-alloy-17mm-extended-nuts/
I have a mixed set @Dino D, shorter front, longer rear, I'll look at the lengths tomorrow.
I also have refurbed wheels and no issues with paint chipping etc. when putting wheels on/off remember that the studs are protruding through a recessed area where the nuts tighten on to.
