Central locking / Alarm
Kenhayes247
Meissendorf, Germany
Good evening all,
I have a question regarding alarm operation and central locking.
I can lock and unlock my doors and boot using the remote key fob without issue. The alarm is meant to arm and disarm along with the door locking/unlocking.
However the alarm only arms if I open and close the passenger door first. I don't need to open and close the passenger door to disarm the alarm.
Any suggestions?
Could be the switch in the door latch on the drivers door Ken.
Drivers as in RH on a UK car Ken. I assumed that the N/S one works as opening and closing it makes the system arm. I have a drivers one to change mid June time to cure an alarm fault on a Z3. Could be wrong, any codes stored?
I can't say how easy or not they are to change Ken, but I'll be able to after June's Shed day. I suspect that the rear wheel arch liner at least will need to come out. The new switch has about 12-15 inches of cable attached.
