Hello.
When I purchased my Z3 last year the third brake light did not work and after reading a little bit on the Internet I found that it is related to the wiring loom.
Sure enough I had a close look at the wiring loom and all the wires were cracked.
I got my soldering iron and soldered the broken wires together and used some heat shrink tubing to secure the wires together.
After connecting all the wires my remote locking decided to stop working. It will arm and disarm the car but won't lock any of the doors. (it's an aftermarket cobra alarm system)
Eventually I found that if I disconnect the brown wire the remote locking works but the light within the boot doesn't work.
Oh I should also mention I've had an issue with locking and unlocking the boot - both with a key and a remote. So if I lock the car from either the passenger or drivers side door the boot will not lock, the boot only locks if I lock the car by placing the key in the boot and turning it (this will also lock both doors in the car). I thought this may be the actuator that's causing the issues so I bought one from @spurs fan in a coupe yesterday and fitted the actuator this morning. After doing so I connected the brown wire in the boot loom again but still I don't have any luck.
It's really frustrating as when I do connect the wire the light inside the boot will work but the remote locking seizes to work. Im also unsure why the boot does not lock with the key or through the remote?
Any thoughts?
P. S I was speaking to @Bozzy about this yesterday and I was almost certain that replacing the actuator would cure the problem.
Any thoughts?
