Hi Folks, I have a vague memory of reading that you could fit the 2.5 inlet manifold to the 2.0 dual vanos to improve engine breathing.....? Anyone know if this is true and if there is a thread anywhere?
Hi Nigel
I too have wounded about this. Below is my thinking to date.
There are threads about fitting the M54B30 manifold to the M52TUB28 to increase the breathing of the engine and give more top end HP, faster revving past 3,500 rpm with a slight drop on torque in the mid rev range. Adding an improved exhaust system and a DME tune to maximize the changes seems to be the ticket. People have done this and like it.
I'm in the process of collecting parts to remove an aged M52TUB25 engine from a 323i and fit a M54B25 engine using the M54's own inlet manifold. The sepc's say there is a 21 HP increase in performance with the M54 engine. It's not just the inlet manifold that is different between the engines to give the boost, the valves are bigger in the M54 engine too = better engine breathing. I'll know more when the job's done.
Now for the 2.0 L Z3 with the M52TUB20 engine.
- 11611439965 is the inlet manifold used on all M52TUB engines from 2.0 to 2.8 L. The M54B30 manifold swap example shows that it is slightly limiting for the 2.8 L engine.
- 11617525752 is the inlet manifold used on the M54 engines 2.0 to 2.5L.
- It has a 11:1 compression ratio, The highest of any M52 or M54 engines. So it is designed for high octane fuel, not regular 91.
My thinking on this is:
- I have not noticed any air restriction limitation on my 2.0 L Z3 with its standard manifold which has been designed for larger engines.
- My daily driving does not see me going above 3,500 rpm, so any top end HP improvement would not be used
- There is not enough mid rev range torque in the engine to sacrifice any for top end HP (which I would not use)
- I have got bigger bangs for my buck from replacing the twin VANOS seals and running the car on premium 98 fuel. The car has gone from sluggish to fun for around town and open road (100 km/h) driving.
So, do your VANOS seals and always run the car on the highest octane rated fuel you have available.
Hope this helps
Regards
Murray
Just another thought, you mentioned the vanos seals. I seem to be quite sluggish until 2500 rpm when you can feel the vanos kick in, is this normal or would new seals help this?Hi Nigel
Hope this helps
Regards
Murray
I thought the M52TUB20 was single VANOS, I too have also looked into the manifold swapHi Folks, I have a vague memory of reading that you could fit the 2.5 inlet manifold to the 2.0 dual vanos to improve engine breathing.....? Anyone know if this is true and if there is a thread anywhere?
New Seals Needed!!!
You may also have a nice cackle from the exhaust pipe at the moment when you put your foot down. This will disappear when you put the seals in. Its a sign of the exhaust VANOS not working.
These two charts are from my Mora 2.0 L Z3 before the VANOS seals were replaced. 97,000 miles on the clock. Haven't got around to doing a retest after the replacement.
- Inlet very jumpy but generally following the reference
- Exhaust jumps to reference or there about's but gets overhauled by the return spring in the exhaust VANOS cylinder e.g oil slipping right past the seal. Hence the cackle in the exhaust note.
If you are going to the effort of replacing the exhaust and a re-tune, then add the M54 inlet manifold. The added cost is not great.
Today I'm looking at the differences between injector fuel rails mounts on the M52TU and M54 manifolds. Working out if the M52TU rail will fit on the M54 manifold to limit the amount of fuel system modifications.
New Seals Needed!!!
Oh now that is very nice indeedy! I want it now!have you seen this pretty thing!
http://www.ebay.co.uk/itm/122287558756?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
isn't it lovely!?Oh now that is very nice indeedy! I want it now!![]()
There are vids on youtube mate, We have a German car specialist near us so I called them for a price, the response I got was not very good at all, basically spoke to me like I was an idiot, "why on Earth would you want them doing"Ok, who has the link to "how to overhaul your vanos" then..........![]()
Thanks Sean, just been trawling utube - looks ok to me. I know what I am doing next weekend!There are vids on youtube mate, We have a German car specialist near us so I called them for a price, the response I got was not very good at all, basically spoke to me like I was an idiot, "why on Earth would you want them doing"
Let me know how you get on, apparently you need to get very good quality seals, is the M52TUB20 duel VANOS, I thought it was singleThanks Sean, just been trawling utube - looks ok to me. I know what I am doing next weekend!![]()
Hi Cuz! certainly can! I will let you know how I get on with it! You made any changes recently to your German mistress?Nigel You can help me do mine next time your over this direction
Info on VANOS seals
http://www.beisansystems.com/
The kit that I use for VNAOS seal replacement. It has everything you need including the anti rattle rings and it comes from the UK.
http://www.ebay.co.uk/itm/BMW-DOUBL...M56-GASKETS-/221946288092?hash=item33ad0797dc
Note of caution on the shinny metal inlet manifold.
- No DISA flap, so you may have issues with engine check light and error codes on your M52TU and M54 engines
- M54B30 and M54B25 uses different sized throttle body mounting to M50, M52 and M52TU. May need an adapter plate.
- BMW have done considerable air flow engineering on their inlet manifolds. Not sure how much has been done for this manifold.
